EvilHamburgerHelper Posted July 21, 2024 at 05:48 PM Share Posted July 21, 2024 at 05:48 PM What do you want to be changed? Get rid of VATS in exchange for a flat Perception Boost of +5 Explanation of suggestion? 1. VATS right now is ass, it works 10-25% of the time. So you're gambling on whether the server or code is working properly so that you can actually shoot your gun and not get a glorified tik tok filter zoom in with numbers flashing. 2. The cost for the Pipboy does not make sense for the shit system it's giving you and therefor would not be bought unless you like to waste money on a unfunctional wearable cosmetic. 3. It turns weapons that were not meant to be medium to long range into glorified DMRs with amazing accuracy. (No a DB or Riot should not become a slug of a weapon, you're meant to be CQC not American Sniper.) The Fix? Make the Pipboy give a flat +5 Perception boost to you when you equip it. (Yes I know FOA has a Perc implant but that's easily removed on PK, No VATS shouldn't "Stay were it is" because otherwise you'd be clogging the server with "shit that should stay were it is") How or why does this benefit the server? Cleaning up the fucking broken system and giving some actual use to the Pipboy. Also an excuse to get rid of VATS so the server has one less thing to be weigh downed. Are there any workshop add-ons or content needed for this suggestion? NO 2 6 Link to comment Share on other sites More sharing options...
ThunderWolf Posted July 22, 2024 at 11:26 PM Share Posted July 22, 2024 at 11:26 PM 60-70k for a item that would now give a Per +5 boost even though modulators and implants exist to reaccumulate that amount? No thanks. -1. Link to comment Share on other sites More sharing options...
Hank Ricci Posted July 24, 2024 at 12:50 AM Share Posted July 24, 2024 at 12:50 AM On 7/22/2024 at 7:26 PM, ThunderWolf said: 60-70k for a item that would now give a Per +5 boost even though modulators and implants exist to reaccumulate that amount? No thanks. -1. Link to comment Share on other sites More sharing options...
Marski Posted July 27, 2024 at 01:15 AM Share Posted July 27, 2024 at 01:15 AM k Link to comment Share on other sites More sharing options...
SargentNoob Posted August 4, 2024 at 09:37 AM Share Posted August 4, 2024 at 09:37 AM I honestly just see this at more options available for more special instead of just focusing Perception I can get other shit aswell like agility Link to comment Share on other sites More sharing options...
Management Haroxan Posted August 4, 2024 at 08:11 PM Management Share Posted August 4, 2024 at 08:11 PM Denied Vat's are already in a fine place, Pipboys don't need a change Link to comment Share on other sites More sharing options...
