Agility stat question
Hoxton
A perception or intel point gives 1% extra damage, up to 30% with 30 points
A luck point gives you 2% extra XP, at 25 luck you get 18 xp from looting a crate and at 0 luck you get 12 xp (at 30 luck its prolly 19.2 xp)
What about agility ? How much does 1 point of agility affect your speed?
Link to comment
Share on other sites
On 5/20/2024 at 7:13 PM, Monolith said:
Not entirely sure but I believe it simply adds 1 velocity to your characters speed.
So 235 base speed with 10 agility is 245 speed.
I think that answers it thank you
do you happen to know if armors that give you 10% speed buff also set you to 245 from 235 speed? Or would it be 258?
The reason for this thread is because I currently have to choose between a hat that gives me 6 special points or one that gives me 5% speed
Link to comment
I think the % speed boost goes off of your default movement speed without any agility. So 5% boost would be 5% of 235 on top of your agility speed.
  • Upvote 1
Link to comment
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
