Spyro Posted May 7, 2024 at 11:26 AM Share Posted May 7, 2024 at 11:26 AM Format: ======================================================== What do you want to be changed? Change Rippers sounds from switchblade to ripper sounds Explanation of suggestion? Currently, the ripper melee weapon uses the switchblade sound effect when swinging, which is annoying because it's a high-pitched sound sometimes played seconds apart and is the wrong sound effect. How or why does this benefit the server? Not cause emission break and annoyance from the repeated high-pitched swinging noise. Are there any workshop add-ons or content needed for this suggestion? Sounds can be found to download from the Wiki or below. https://fallout.fandom.com/wiki/Ripper_(Fallout_3) Attack Sound: Wpn_Ripper_fire_lpm.ogg Idle Sound: Wpn_Ripper_idle_lpm.ogg ======================================================== 4 Link to comment Share on other sites More sharing options...
Logman Posted May 8, 2024 at 12:21 AM Share Posted May 8, 2024 at 12:21 AM +1 Link to comment Share on other sites More sharing options...
Dazed Posted May 8, 2024 at 02:52 AM Share Posted May 8, 2024 at 02:52 AM +1 Link to comment Share on other sites More sharing options...
bighoncho Posted May 8, 2024 at 04:46 AM Share Posted May 8, 2024 at 04:46 AM i made that weapon why are you using it Link to comment Share on other sites More sharing options...
josh9023 Posted May 8, 2024 at 04:58 AM Share Posted May 8, 2024 at 04:58 AM +1 Link to comment Share on other sites More sharing options...
Francey Posted May 11, 2024 at 06:28 PM Share Posted May 11, 2024 at 06:28 PM Positive, no reason not to add this fix Link to comment Share on other sites More sharing options...
Garrus Posted May 11, 2024 at 11:18 PM Share Posted May 11, 2024 at 11:18 PM Accepted Forwarded to Devs. Link to comment Share on other sites More sharing options...
