[ Balance ] USAR Faction Lead Armor Fix
Spyro
Format:
What do you want to be changed?
To make the USAR armor faction lead armor in line with the rest of the servers faction lead armor
Explanation of suggestion?
Currently, the USAR faction lead armour (US ARMY T-49 Power Armor ) has default T-60 stats; I propose that it be changed to be in line with the rest of the custom faction lead armour.
Proposed stats change:
DR: 85
Speed: -25
Jump: -15
How or why does this benefit the server?
To make it so all factions are in line with each other and no faction is punished.
Are there any workshop add-ons or content needed for this suggestion?
N/A
Edited by Spyro
  • Vault Boy Thumbs-Up 2
  • Upvote 7
Link to comment
Share on other sites
Partially Accepted
Not all Faction Leader Armors are created equal. Otherwise Great Khan Papa Khan, Minutemen General Coat, etc would all have the same statline. I would agree FL armors should be stronger than the average but it doesn't mean they will be equal to each other. It will see a stat increase but it may not be what you are asking for.
  • Downvote 1
Link to comment
  • Garrus locked this topic
Guest
This topic is now closed to further replies.
