Spyro Posted March 14, 2024 at 11:07 AM Share Posted March 14, 2024 at 11:07 AM Format: ======================================================== What do you want to be changed? Our Enlisted armor is less than adequate, They are all quite simpler and our MK2 & MK1 have the same stats. Explanation of suggestion? CURRENT STATS Army Combat Armor MKII & MKI DR: 63 Speed: 0 Army Recon Armor DR: 65 Speed: 0 PROPOSED CHANGE Army Combat Armor MKI DR: 63 Speed: 0 Army Combat Armor MKII DR: 65 Speed: 0 Army Recon Armor DR: 60 Speed: 5 How or why does this benefit the server? The USAR Enlisted armor is lacking in some places, especially our MK1 & MK2 which possess the same stats which doesn't make much sense as it is an upgraded variant. Our Recon Armor is not very good so a speed increase could add some difference to make it unique compared to each other. Are there any workshop add-ons or content needed for this suggestion? N/A ======================================================== 13 1 Link to comment Share on other sites More sharing options...
Bongo Posted March 14, 2024 at 12:10 PM Share Posted March 14, 2024 at 12:10 PM Brother In christ these stats for enlisted armour are more then good already!!! -1 Link to comment Share on other sites More sharing options...
Garrus Posted March 14, 2024 at 12:41 PM Share Posted March 14, 2024 at 12:41 PM Customs with so few armors should not have reskins stats, plus I hate same stat armor sets, so I would agree to a change. Generally speaking, the more PA you have, the weaker your enlisted armors should be. So if I recall correctly, USAR only have T51, right? So Bongo, them having 63 enlisted isn't too crazy, considering Desert Rangers have 70 DR armor sets whilst possessing PA. On the other hand, 63 DR enlisted armor is pretty freaking good. I don't think you realize how good that is, especially when you possess PA greater than T45. There are other options for stat buffs besides DR and SB like fall protection or END buff in case you wanted to change it that way. Link to comment Share on other sites More sharing options...
borker Posted March 14, 2024 at 12:50 PM Share Posted March 14, 2024 at 12:50 PM On 3/14/2024 at 7:41 AM, Garrus said: Customs with so few armors should not have reskins stats, plus I hate same stat armor sets, so I would agree to a change. Generally speaking, the more PA you have, the weaker your enlisted armors should be. So if I recall correctly, USAR only have T51, right? So Bongo, them having 63 enlisted isn't too crazy, considering Desert Rangers have 70 DR armor sets whilst possessing PA. On the other hand, 63 DR enlisted armor is pretty freaking good. I don't think you realize how good that is, especially when you possess PA greater than T45. Perhaps a fall protection or END buff or something besides DR for the MK2 and Recon? they have t60 tier armor Link to comment Share on other sites More sharing options...
Spyro Posted March 14, 2024 at 01:33 PM Author Share Posted March 14, 2024 at 01:33 PM (edited) On 3/14/2024 at 10:40 PM, Bongo said: Brother In christ these stats for enlisted armour are more then good already!!! -1 The purpose of the change is to make the armors more unique, compared to each other. Edited March 14, 2024 at 01:33 PM by Spyro Link to comment Share on other sites More sharing options...
Bongo Posted March 14, 2024 at 02:25 PM Share Posted March 14, 2024 at 02:25 PM (edited) On 3/14/2024 at 9:33 AM, Spyro said: The purpose of the change is to make the armors more unique, compared to each other. What the fuck is so unique about ur faction? All you do is pvp Correction. All you do is pvp and be good guys of the wastes, you are just another generic $1000 custom faction. Edited March 14, 2024 at 05:22 PM by Bongo 1 1 Link to comment Share on other sites More sharing options...
Robbytheone Posted March 14, 2024 at 06:12 PM Share Posted March 14, 2024 at 06:12 PM +1 none of the proposed changes hurt and would give sort of a more unique feel to their enlisted armor? Link to comment Share on other sites More sharing options...
Atomik Posted March 15, 2024 at 01:42 PM Share Posted March 15, 2024 at 01:42 PM On 3/14/2024 at 7:07 AM, Spyro said: Our Recon Armor is not very good so a speed increase could add some difference to make it unique compared to each other. how far fallout rp has fallen where 65 dr is considered "not good" Link to comment Share on other sites More sharing options...
Toni0 Posted March 16, 2024 at 10:01 PM Share Posted March 16, 2024 at 10:01 PM Approved for research project. Make proposal. Link to comment Share on other sites More sharing options...
