[ Balance ] Weapon Balance Aug
BearGrills11
What do you want to be changed?
Buff the AUG to high end standards
Explanation of suggestion?
Currently the stats for the Steyr AUG at uncommon does
42 dmg
300 RPM
3 || 0
These stats make the gun exactly the same as the marksman carbine.I would ask for much higher dmg and a higher rpm cause currently it is not a high end also its 1 every 6 weeks at 40K
Proposed Stat Changes:
60dmg base
400-450 rpm
3 || 0
How or why does this benefit the server?
Will make the gun worth using and not a 40K Uncommon Marksman Carbine
Are there any workshop add-ons or content needed for this suggestion?
N/A
Edited by BearGrills11
  • Upvote 10
  • Downvote 1
Link to comment
Share on other sites
On 12/4/2023 at 9:45 PM, Seeker said:
1 week before launch btw. AUG did 60dmg or something insane before nerf. Marksman is getting nerfed apparently. 3 round burst, super accurate gun.
help us help you
Alright i get that about the lock thats fine, but you decided the aug is a high end when its worse stats than a marksman carbine which is not a High End, as well no one uses it on the 3 round burst mode due to it bouncing the scope way too much. You cant argue that this gun is a high end cause then you'd have to call the marksman carbine a high end
  • Upvote 1
Link to comment
  • Scott locked this topic
Guest
This topic is now closed to further replies.
